I share a large number of weldment profiles with my co-workers. These profiles are shared in PDM vaults and they are working fine on other machines. They have always worked in 2018 and we use them intermittently. These profiles do work in 2019 but they don't populate the weldment drop down list unless they have been opened at least once in the past. That would be fine if it was only 20-30 profiles but since we are using 100's and can only open a few at a time is there a way to automate opening and closing the profiles so they populate? Thanks.
Since you're using a PDM vault, is it a matter of caching a local copy of the profiles?
I haven't seen the problem as you describe it, but I know that a Design Library will not display "vaulted" components in the library until they are cached.
