I have 1 LimitDistance and 3 LimitAngle mates in my assembly with 2 sub-assemblies that don't need to move. I can pick the LimitDistance and only 1 of the 3 LimitAngle mates. What would cause the other 2 mates to be unavailable for use in the Mate Controller?
The LimitAngle mates are using Work Planes for the mating surfaces because most of the parts in the assembly are created with imported surfaces.
Using SolidWorks 2017 x64 Edition SP 4.1
For some reason it doesn't like that your limits go negative. Probably some kind of limitation on the sliders or something. This should really be outlined in the documentation. Add planes such that your angle limits go from zero to the appropriate value. I'm using 2018 and saw the same behavior, but changing to only positive angle values worked.
