Looping through selected faces to get section properties
Question asked by Tony Truong on Mar 27, 2019
The following example code outputs section properties for all selected faces together. I am looking to modify this code to output the section properties for all selected faces individually.
My initial thought is to add a For loop at vSelObj = swSelObj but I do not know how to index through the objects.
Any help would be greatly appreciated.
' Preconditions:
' 1. Open a part, fully resolved assembly, or drawing.
' 2. Select one of the following:
' * Sketch
' * Planar model face
' * Face on a section plane
' * Crosshatch section face in a section view
' in a drawing or a sketch
' 3. Open the Immediate window.
' Postconditions:
' 1. Maintains the selection set. (See NOTES)
' 2. Examine the Immediate window.
' NOTES:
' * Array of objects passed into this method are
' added to the selection set.
' * Outputted values are the same as those obtained
' through the user interface.
' * Reasons for failures are the same as those
' in the user interface.
Option Explicit
Const PI As Double = 3.14159
Dim swModelExt As SldWorks.ModelDocExtension
Dim swFace As SldWorks.Face2
Dim swFeat() As SldWorks.Feature
Dim swFaceEnt() As SldWorks.Entity
Dim swSketch As SldWorks.Sketch
Dim nSelType As Long
Dim swSelObj() As Object
Dim vSelObj As Variant
Dim vSectionProp As Variant
Dim nSelCount As Long
Dim nNumObj As Long
Dim i As Long
Set swModel = swApp.ActiveDoc
Set swModelExt = swModel.Extension
Debug.Print "File = " & swModel.GetPathName
nSelCount = swSelMgr.GetSelectedObjectCount
For i = 1 To nSelCount
nSelType = swSelMgr.GetSelectedObjectType2
Debug.Print " SelType(" & i & ") = " & nSelType
Select Case nSelType
Case swSelFACES, swSelREFSURFACES
nNumObj = nNumObj + 1
ReDim Preserve swSelObj(nNumObj - 1)
ReDim Preserve swFaceEnt(nNumObj - 1)
Set swFace = swSelMgr.GetSelectedObject5
Set swFaceEnt(nNumObj - 1) = swFace
Set swSelObj(nNumObj - 1) = swFace
Case swSelSKETCHES
ReDim Preserve swFeat(nNumObj - 1)
Set swFeat(nNumObj - 1) = swSelMgr.GetSelectedObject5
Set swSketch = swFeat(nNumObj - 1).GetSpecificFeature
Set swSelObj(nNumObj - 1) = swSketch
Debug.Print " " & swFeat(nNumObj - 1).Name
Case swSelMANIPULATORS
' Section face in a part or assembly when in a section view
' There is no corresponding API object for this,
' so leave it selected
End Select
Next i
Debug.Print ""
' Deselect faces and sketches; otherwise, user-interface selections
' are added to array parameter; leave section faces selected
If Not IsEmpty(swFaceEnt) Then
For i = 0 To UBound(swFaceEnt)
swFaceEnt(i).DeSelect
Next i
If Not IsEmpty(swFeat) Then
For i = 0 To UBound(swFeat)
swFeat(i).DeSelect
Next i
vSelObj = swSelObj
' This adds the array of faces or sketches to the selection set
' Because the faces or sketches have been deselected, this
' preserves the selection set
vSectionProp = swModelExt.GetSectionProperties((vSelObj))
' Return code from:
' IModelDocExtension::GetSectionProperties
' 0 = success
' 1 = invalid input
' 2 = selected faces are not in the same or parallel planes
' 3 = unable to compute section properties
Debug.Print " Return code = " & vSectionProp(0)
Debug.Print ""
Debug.Print " Area = " & vSectionProp(1) * 1000000# & " mm^2"
Debug.Print " Centroid = (" & vSectionProp(2) * 1000# & ", " & vSectionProp(3) * 1000# & ", " & vSectionProp(4) * 1000# & ") mm"
Debug.Print " Ixx = " & vSectionProp(5) * 1000000000000# & " mm^4"
Debug.Print " Iyy = " & vSectionProp(6) * 1000000000000# & " mm^4"
Debug.Print " Izz = " & vSectionProp(7) * 1000000000000# & " mm^4"
Debug.Print " Ixy = " & vSectionProp(8) * 1000000000000# & " mm^4"
Debug.Print " Izx = " & vSectionProp(9) * 1000000000000# & " mm^4"
Debug.Print " Iyz = " & vSectionProp(10) * 1000000000000# & " mm^4"
Debug.Print " Polar MOI = " & vSectionProp(11) * 1000000000000# & " mm^4"
Debug.Print " Angle princ & part axes = " & vSectionProp(12) * 180# / PI & " deg"
Debug.Print " Ix = " & vSectionProp(13) * 1000000000000# & " mm^4"
Debug.Print " Iy = " & vSectionProp(14) * 1000000000000# & " mm^4"
