I never used the 'enable on screen numeric input' before, but a colleague uses it all the time and I thought I'd try it out. Problem: when I click to begin a rectangular shape for example, I can type in my dimensions fine. But when the sketch is complete, the dimensions I input are 'driven' whereas on his system they're 'driving'.
Under System>Options>Sketch, all our settings are identical:
I've even opened his part template, and still I cannot make it so these dimensions are driving. Is this controlled by some other setting?
I also use that feature frequently, and the only time I've had a dimension driven is if the cursor was close to another entity and the point snapped to it instead of using my entered value (which irritates me to no end). I can't imagine what could be causing all dimensions entered to be driven. I assume you've watched your co-worker to make sure you're using the same workflow?
Just to double-check, you:
