Log in to create and rate content, and to follow, bookmark, and share content with other members.
I am trying to make a thin extrusion, but the check box is grey and not allowing me to select it. There is nothing else on the drawing other than the line I want to extrude. Why can't I select?
To build on that, a thin extrusion cannot be unselected when you have an open profile. For example, if you sketch one straight line and then try to make a solid extrusion from that, the only way that can happen is if the extrusion feature adds thickness so it selects the thin feature for you.
Thanks, I did realize that even though it was greyed, it was generating my extrusion. It just didn't happen the way I expected. (I had preview turned off, which made me think nothing was working).
Looks like its selected already. Notice the light grey check.
Its grey out so you can't de-select.
