Hey Folks,
I am running an internal flow of some extrusion die plates. I have successfully lidded up the model and added flow conditions. Check Geometry passes and shows a seemingly correct fluid volume. When meshing, however, it returns a Fluid Cell count at (or near in some tries) zero. Any ideas? I can upload the assembly if necessary. I feel like I have something simple switched off, but can't seem to flesh it out.
Kevin
Message was edited by: Kevin Klemarczyk Attachment added.
I have looked at your model and get the message that it is not watertight. So there seem to be some gaps between the parts of the die. Is the geometry imported? I have seen it before with an imported model of a ballbearing.
