solidworks does not let you create the sweep with any of the solid or surface options, can someone help me understand why?
Victor Orrego wrote:
I have solid 2018, it appears that this version is more advanced
What MB did also works in SOLIDWORKS 2018. Here is your original model with the sweep working.
Let me explain what is happening. As you see in your video, if you only choose a profile and a path ONLY, then the profile is free to twist as it wants around the path. It doesn't twist arbitrarily, but actually keeps the same orientation to the original curve all the way along the path. But you want the profile to stay upright in the Z direction as it sweeps along the path. You can force it to do this by using your second curve as a guide to control the twist. So, choose the 2nd curve as a guide curve and then ignore the first option in the Options group box. The 2nd option in the options group box controls the twist of the profile about the path (which is exactly what you want to control). And if you choose the option for Follow Path and First Guide Curve, it will use your guide curve to control the twist (making the profile stay in the same relative position to both curves).
I hope this helps,
Jim
Impossible, no. Undesirable, yes.
You will need to add more control to your sketches to reduce the profile distortion. If you want to specify the profile at specific points along the path I would suggest using lofted sections rather than one continuous sweep.
