Does someone know if i can open a STEP file from SW 2018 to SW 2016 and convert all his properties as a correct design??
I need to open all the components of one machine designed in SW 2018 but i have the 2016 SW licence.
Thank you!
Thank you!
Thank you!
Yes
Maybe not
Test one part and see if you get everything you need.
It will open as a dumb solid with no feature tree.
He will not be able to save a version for you that will be able to open with a full feature tree. SolidWorks , as most all 3D solid modeling software is not backwards compatible.
Did you try it.... ??
A STEP file is static, a dummy solid, should work..
