I have solidworks 2009 premium but i cant find simulation
premium. I only have simulation Xpress ,wich is the basic. Do i
have to activate it or doesn't it come with the premium package?
Some information please.
Check your serial no. if it is solidworks premium means, it will
automatically install solidworks simulation, solidworks motion etc.
use solidworks installation manager while installing the
solidworks. then select the solidworks simulation from the add in.
I agree with Ameer, you have to check the the proper box in the
"Add-in" options. Simulation Xpress is available until you "Add-In"
Solidworks Simulation.
Simulation premium comes as a seperate license. Check under
the solidworks license administrator tool and if you have
simulation premium installed you will see it in the License
box.
Check your serial no. if it is solidworks premium means, it will automatically install solidworks simulation, solidworks motion etc. use solidworks installation manager while installing the solidworks. then select the solidworks simulation from the add in.
