Hi everyone,
This macro will draw small red lines at each bend lines extremities on a sheet metal drawing.
It is based on John Alexanderreply on this thread: Troubleshooting mathTransforms, ivertex getpoints, and Views/Sketches.
it will work with rotated views and bend lines with angles.
Option Explicit Dim swApp As SldWorks.SldWorks Dim swModel As SldWorks.ModelDoc2 Dim swDraw As SldWorks.DrawingDoc Dim swView As SldWorks.View Dim swMathUtil As SldWorks.MathUtility Dim BendlinesArr As Variant Dim Bendline As Variant Dim swSketch As SldWorks.Sketch Dim swModelToViewXForm As SldWorks.MathTransform Dim swModelToSketchXForm As SldWorks.MathTransform Dim swDrawingToViewXForm As SldWorks.MathTransform Dim swSketchLine As SldWorks.SketchLine Dim swSkStartPt As SldWorks.SketchPoint Dim swSkEndPt As SldWorks.SketchPoint Dim swSketchSeg As SldWorks.SketchSegment Dim nPt(2) As Double Dim vPt As Variant Dim swStartPt As SldWorks.MathPoint Dim swEndPt As SldWorks.MathPoint Dim X1 As Double, Y1 As Double, X2 As Double, Y2 As Double Dim X3 As Double, Y3 As Double, X4 As Double, Y4 As Double Dim Length As Double, Delta As Double Sub main() Set swApp = Application.SldWorks Set swMathUtil = swApp.GetMathUtility Set swModel = swApp.ActiveDoc Set swDraw = swModel Set swView = swDraw.GetFirstView Set swView = swView.GetNextView Dim swLayerMgr As SldWorks.LayerMgr Set swLayerMgr = swModel.GetLayerManager Dim SavedLayerName As String SavedLayerName = swLayerMgr.GetCurrentLayer 'Optional: Add lines to new layer 'swLayerMgr.AddLayer "myNewLayer", "", 0, 0, 0 'Optional: Add lines to existing layer 'swLayerMgr.SetCurrentLayer "myExistingLayer" While Not swView Is Nothing If swView.IsFlatPatternView Then swDraw.ActivateView swView.GetName2 If swView.GetBendLineCount > 0 Then BendlinesArr = swView.GetBendLines For Each Bendline In BendlinesArr Set swSketchLine = Bendline If swSketchLine.IsBendLine Then Set swSkStartPt = swSketchLine.GetStartPoint2 Set swSkEndPt = swSketchLine.GetEndPoint2 Set swSketch = swSketchLine.GetSketch Set swModelToSketchXForm = swSketch.ModelToSketchTransform.Inverse Set swModelToViewXForm = swView.ModelToViewTransform Set swDrawingToViewXForm = drawingToViewTransform(swView).Inverse nPt(0) = swSkStartPt.X nPt(1) = swSkStartPt.Y nPt(2) = swSkStartPt.Z vPt = nPt Set swStartPt = swMathUtil.CreatePoint(vPt) Set swStartPt = swStartPt.MultiplyTransform(swModelToSketchXForm) Set swStartPt = swStartPt.MultiplyTransform(swModelToViewXForm) Set swStartPt = swStartPt.MultiplyTransform(swDrawingToViewXForm) nPt(0) = swSkEndPt.X nPt(1) = swSkEndPt.Y nPt(2) = swSkEndPt.Z vPt = nPt Set swEndPt = swMathUtil.CreatePoint(vPt) Set swEndPt = swEndPt.MultiplyTransform(swModelToSketchXForm) Set swEndPt = swEndPt.MultiplyTransform(swModelToViewXForm) Set swEndPt = swEndPt.MultiplyTransform(swDrawingToViewXForm) X1 = swStartPt.ArrayData(0) Y1 = swStartPt.ArrayData(1) X2 = swEndPt.ArrayData(0) Y2 = swEndPt.ArrayData(1) Set swSketchSeg = swSketchLine 'set lines length to 3mm Delta = 0.003 Length = swSketchSeg.GetLength X3 = (X2 - X1) * Delta / Length + X1 Y3 = (Y2 - Y1) * Delta / Length + Y1 X4 = (X1 - X2) * Delta / Length + X2 Y4 = (Y1 - Y2) * Delta / Length + Y2 'make lines start at 0.5 mm from edges Delta = 0.0005 X1 = (X2 - X1) * Delta / Length + X1 Y1 = (Y2 - Y1) * Delta / Length + Y1 X2 = (X1 - X2) * Delta / Length + X2 Y2 = (Y1 - Y2) * Delta / Length + Y2 swModel.SetAddToDB True Set swSketchSeg = swModel.SketchManager.CreateLine(X1, Y1, 0#, X3, Y3, 0#) swSketchSeg.Color = RGB(255, 0, 0) Set swSketchSeg = swModel.SketchManager.CreateLine(X2, Y2, 0#, X4, Y4, 0#) swSketchSeg.Color = RGB(255, 0, 0) swModel.SetAddToDB False End If Next End If End If Set swView = swView.GetNextView Wend swLayerMgr.SetCurrentLayer SavedLayerName swModel.ClearSelection2 True End Sub Function drawingToViewTransform(swView As SldWorks.View) As SldWorks.MathTransform Dim swMathUtil As SldWorks.MathUtility Dim transformData(15) As Double Set swMathUtil = swApp.GetMathUtility transformData(0) = Cos(swView.Angle) transformData(1) = Sin(swView.Angle) transformData(2) = 0# transformData(3) = -Sin(swView.Angle) transformData(4) = Cos(swView.Angle) transformData(5) = 0# transformData(6) = 0# transformData(7) = 0# transformData(8) = 1# transformData(9) = swView.Position(0) transformData(10) = swView.Position(1) transformData(11) = 0# transformData(12) = swView.ScaleDecimal transformData(13) = 0# transformData(14) = 0# transformData(15) = 0# Set drawingToViewTransform = swMathUtil.CreateTransform(transformData) End Function
Awesome Stuff Fifi Riri - Thank you
