Macro to automatically convert all part files into IGES
Question asked by Andy Krol on Mar 19, 2019
Latest reply on Apr 23, 2019 by Abhishek Lad
Can anyone help me with this:
I have this Macro created by Deepak Gupta (thanks so much for this), that converts all the drawings in the specified folder and converts them to PDF and saves them all in a PDF sub folder. This macro is a lifesaver for me as I do it all the time and it's much faster than Task Scheduler.
I'm trying to modify this Macro to to perform same tasks, but instead of converting drawings (.SLDDRW) to PDF, I want the macro to convert all the part files (.SLDPRT) to IGES and Save them in IGS sub folder.
here is the original Macro file that converts drawings to PDF, can anyone help with modifying it?
Thanks in Advance
' Written by: Deepak Gupta (http://gupta9665.com/)
Option Explicit
Private Const BIF_RETURNONLYFSDIRS As Long = &H1
Private Const BIF_DONTGOBELOWDOMAIN As Long = &H2
Private Const BIF_RETURNFSANCESTORS As Long = &H8
Private Const BIF_BROWSEFORCOMPUTER As Long = &H1000
Private Const BIF_BROWSEFORPRINTER As Long = &H2000
Private Const BIF_BROWSEINCLUDEFILES As Long = &H4000
Private Const MAX_PATH As Long = 260
Function BrowseFolder(Optional Caption As String, Optional InitialFolder As String) As String
Dim SH As Shell32.Shell
Dim F As Shell32.Folder
Set SH = New Shell32.Shell
Set F = SH.BrowseforFolder(0&, Caption, BIF_RETURNONLYFSDIRS, InitialFolder)
If Not F Is Nothing Then
    If F = "Desktop" Then
        BrowseFolder = Environ("USERPROFILE") & "\Desktop"
    Else
        BrowseFolder = F.Items.Item.Path
End Function
Sub Main()
Dim swApp        As SldWorks.SldWorks
Dim swModel      As SldWorks.ModelDoc
Dim sFileName    As String
Dim Path         As String
Dim PDFpath      As String
Dim nErrors      As Long
Dim nWarnings    As Long
Dim swDraw       As SldWorks.DrawingDoc
Dim PartNoDes    As String
Dim swExportPDFData As SldWorks.ExportPdfData
    Set swExportPDFData = swApp.GetExportFileData(1)
    swExportPDFData.ViewPdfAfterSaving = False
    Path = BrowseFolder("Select a Path/Folder")
    If Path = "" Then
        MsgBox "Please select the path and try again"
        End
    Else
    Path = Path + "\"
    PDFpath = Path & "PDF"
    If Dir(PDFpath, vbDirectory) = "" Then MkDir PDFpath
    sFileName = Dir(Path & "*.slddrw")
    Do Until sFileName = ""
        Set swModel = swApp.OpenDoc6(Path + sFileName, swDocDRAWING, swOpenDocOptions_Silent, "", nErrors, nWarnings)
        Set swModel = swApp.ActiveDoc
        Set swDraw = swApp.ActiveDoc
            PartNoDes = Mid(swDraw.GetPathName, InStrRev(swDraw.GetPathName, "\") + 1)
            PartNoDes = Left(PartNoDes, Len(PartNoDes) - 7)
            swDraw.SaveAs3 PDFpath & "\" & PartNoDes & ".PDF", 0, 0
        swApp.QuitDoc swDraw.GetPathName
        Set swDraw = Nothing
        Set swModel = Nothing
        sFileName = Dir
    Loop
MsgBox "All Done"
