Macro to add a cut list propertie just to sheet metal items?
Question asked by Guilheme Azevedo on Mar 17, 2019
Latest reply on Apr 14, 2020 by Arif Akbas
HI everyone! How are  you doing?! I´m having troubles to add a cut list propertie to each sheet metal part inside my multibody project. For example: I want to add a property "Description" with has the value "  anything". I took a macro in this forum that does it, but it add the propertie to the weldments too, like tubes or extrusion bodyes.
Dim swModelDocExt As SldWorks.ModelDocExtension
Dim swFeat As SldWorks.Feature
Dim swDeleteFaceFeature As SldWorks.DeleteFaceFeatureData
Dim swCustPropMgr As SldWorks.CustomPropertyManager
Dim names As Variant
Dim textexp As String
Dim evalval As String
Dim featureName As String
Dim boolstatus As Boolean
Dim opt As Long
    Set swModel = swApp.ActiveDoc
    Set swModelDocExt = swModel.Extension
    ' Get the DeleteFace feature
    Set swFeat = swModel.FirstFeature
     Do While Not swFeat Is Nothing
        If swFeat Is Nothing Then
            Exit Do
        featureName = swFeat.Name
There is a way to say the SoliWorks: " Hey buddy, from here to bottom let just sheet metals pass thrugh! ".
        If swFeat.GetTypeName2 = "CutListFolder" Then
             boolstatus = swModelDocExt.SelectByID2(featureName, "SUBWELDFOLDER", 0, 0, 0, False, 0, Nothing, 0)
             swModelDocExt.Create3DBoundingBox
            Set swCustPropMgr = swFeat.CustomPropertyManager
            swCustPropMgr.Add3 "Description", swCustomInfoType_e.swCustomInfoText, " Chapa # " & """SW-Espessura da Chapa metálica@@@" & swFeat.Name & "@" & FileName & ".SLDPRT""" & " x """ & "SW-Comprimento da Caixa delimitadora@@@" & swFeat.Name & "@" & FileName & ".SLDPRT""" & " x """ & "SW-Largura da Caixa delimitadora@@@" & swFeat.Name & "@" & FileName & ".SLDPRT""", swCustomPropertyAddOption_e.swCustomPropertyDeleteAndAdd
        Debug.Print swFeat.GetTypeName2
        Set swFeat = swFeat.GetNextFeature
    Loop
    MsgBox "Done"
