we are very new with PDM Professional.
We have now adjusted the data card and added (new) additional variables to be displayed on the data card.
The variables are mapped to the custom property from Drawings. (These variables are stored in the properties of the drawing "$prp"...not linked to the model)
From the existing drawings the data will not be applied until the drawings are checked out and checked back in. This could be done as an administrator, then the workflow does not need to be changed. However, a lot of data is generated (more than 10,000 drawings).
Is there a other way to update the Data Cards without checking out/in all the files? How can i update the DataCards? Can this be done through the API? Or a Dispatch script?
Regards
Sascha
Hi Sascha,
The files must be checked out in order to update them. The variables can be updated in batch by using a Dispatch script, a program written using the API or the highly valuable but little known Update Values in Files command.
