I've created assembly, but now I just want to draw a sketch of a couple lines and then make those lines into weldments, (Beams) is this possible if so how do you do it? I can't click on my weldment tool bar while I'm in an assembly
The sketch need s to reside in the part you are trying to make into a weldment. You can create a sketch in your part while in the assembly and select the convert entities to convert the entities of your sketch in your assembly into your part.
