While using the "Mate" command, I used to be able to right click a component and "Hide" it to get it out of the way. Since upgrading to 2019 this functionality is missing. Is there a setting somewhere to bring back this functionality?
I'm not on 2019, but can you still TAB and hide in the function?
It doesn't appear to work either, but I've never used that function so I may not be applying it properly.
Scott Perman wrote: It doesn't appear to work either, but I've never used that function so I may not be applying it properly.
Scott Perman wrote:
2018 tab doesn't hide in function either. Just tested it. My RMB Hide option is there though.
Go to 'customize menu' after you right click and didn't see 'hide'.
I downloaded SP2 today, and it solved the problem.
