I have had this continuous problem with my model which repetitively fails no matter how i change the settings. After many resets of the study it eventually works, but there is nothing that I can do to make it work apart from repetitively running the study until it works. Has anyone seen this error before and knows how to fix it?
This can indicate an unstable setup that contains No Penetration contact with the Large Displacement option enabled. There could also be an issue with the range of material properties assigned to components in the study.
Please click here to view SOLIDWORKS Knowledge Base (KB) solution S-071868 which contains detailed troubleshooting/resolution information (the blue text at the bottom of the Simulation error message also contains a link to this KB solution).
Be sure to contact your SOLIDWORKS Value Added Reseller (VAR) to troubleshoot this issue if the KB solution does not help you move forward. To get the most efficient help possible, send your VAR a SOLIDWORKS Rx Problem Capture with video that shows the behavior as well as your model files.
