When using the Rapid Dimension tool the automatic placement of the top dimension (60mm) is a bit close to the bottom dimensions (15, 30,15mm).
I know I can move it slightly further away by dragging it before or after placing, but can someone tell me what setting I need to change to have the automatic top dimension further away from the bottom dimensions.
Mark (SolidWorks 2019 sp1)
document properties:
