Hello. One thing I liked about Eplan was the ability to move several wires at one time and connect the terminals between the wired components automatically.
For example, in the figure below, I have three wires. Is it possible for me to move these three wires to the next component at the same time?Or is it possible for me to connect the terminals between the wired components automatically, just as Eplan did?
Thank you guys.
You just have to change your process a little bit. One way is draw the wires before you place your symbols, and they will auto-trim as needed. Or the other way is drop your symbols, and then draw the wires through all of the symbols, and they will auto-trim. From your picture there, the only way to extend the wires would be individually. Select the endpoint of the wire, and drag it as far as you want to go, and it will auto-trim.
