6 Replies Latest reply on Mar 15, 2019 7:10 AM by Marco Cruz
    Ask and wait to select a plane with macros
    Marco Cruz
      Hi.
      I have created many macros, but I am having some dificulty with a simple easy task.
      I want to create a sketch in user choosen plane.
      I know I could do it on a pre-defined plane, but I need to be able to choose it.
      This isnt enough:
      Set Part = swApp.ActiveDoc
      Part.SketchManager.InsertSketch True
      boolstatus = Part.Extension.SelectByID2("Right Plane", "PLANE", 0, 1, 1, False, 0, Nothing, 0)
      Part.ClearSelection2 True
      any ideas?
      Thanks!
        • Re: Ask and wait to select a plane with macros
          Rob Edwards
          Can the user pre-select the plane before they run the macro?
          If so use the selection manager, check it's a plane and you're good to go
            Josh Brady
            Please see:
            Beginner API - DASSAULT: SOLIDWORKS 3D Design - Eng-Tips
            User "handleman" posted an example of a quick-and-dirty way to prompt the user to select something and then wait for a selection.  As discussed in that thread, WithEvents is a better, more robust way to do it.  However, it's not nearly as straightforward.
              Simon Turner
              I would create a Property Manager Page with a selection box in it. Then SolidWorks will handle things like only allowing to select certain types of object.
                Marco Cruz
                Hi.
                Thank you all for the replies.
                I have sucessfully made the script I wanted.
                Here are the steps the script makes:
                1) create new part
                2) ask to select a plane, and start a sketch on it
                3) "project" planes to sketch
                Thanks!
                EDIT: Macro on next post
                    Marco Cruz
                    UPDATE:
                    I need to show planes fot easier user selection.
                    I have following code, but it hides planes on selection. Any way to avoid this?
                    EDIT: Fixed. Complete Macro:
                        On Error Resume Next
                        Dim swApp               As Object
                        Dim swModel             As SldWorks.ModelDoc2 'As Object
                        'Dim Part                As Object
                        Dim SketchLine          As Object
                        Dim SelMgr              As SldWorks.SelectionMgr 'As Object
                        Dim nContinue           As Integer
                        Dim SelType             As SwConst.swSelectType_e
                        Dim sMsg                As String
                        Dim i                   As Long
                        Dim swDoc               As SldWorks.ModelDoc2
                        Dim boolstatus          As Boolean
                        'CREATE NEW FILE
                        Set swModel = swApp.NewDocument("T:\3 - CONFIG\5 - SOLIDWORKS\1 - TEMPLATES\Part.prtdot", 0, 0, 0)
                        'SHOW PLANES
                        boolstatus = swModel.Extension.SelectByID2("Front Plane", "PLANE", 0, 0, 0, True, 0, Nothing, 0)
                        swModel.UnBlankRefGeom
                        boolstatus = swModel.Extension.SelectByID2("Top Plane", "PLANE", 0, 0, 0, True, 0, Nothing, 0)
                        boolstatus = swModel.Extension.SelectByID2("Right Plane", "PLANE", 0, 0, 0, True, 0, Nothing, 0)
                        swModel.ClearSelection2 True
                        'CREATE SKETCH ON SELECTED PLANE
                        Set SelMgr = swModel.SelectionManager
                        MsgBox "Please select a plane..."
                        While SelMgr.GetSelectedObjectType3(1, -1) <> swSelectType_e.swSelDATUMPLANES
                            While SelMgr.GetSelectedObjectCount < 1
                                DoEvents
                            Wend
                        Wend
                        'CREATE SKETCH
                        swModel.SketchManager.InsertSketch True
                        'CREATE CENTER LINES
                        Set SketchLine = swModel.CreateLine2(0#, 1, 0#, 0#, -1, 0#)
                        SketchLine.ConstructionGeometry = True
                        SketchLine.MakeInfinite
                        Set SketchLine = swModel.CreateLine2(1, 0#, 0#, -1, 0#, 0#)
                        'SHOW PLANES
                        swModel.BlankRefGeom
