VBA - Remove (or prevent adding) duplicates from/to a listbox.
Question asked by Cad Admin on Mar 14, 2019
Latest reply on Mar 14, 2019 by Cad Admin
General VB, i have a single column, multi-select listbox i am populating with file paths from components in an assembly.  I need to add the path ONLY if it doesn't already exist.
i can either do it as i process the components of the assembly, or after the fact.  I would prefer while.  that being said the function below is giving me an error. of: "vba could not get the list property. invalid property array index"
Private Function AddListBoxItem(pathName As String) As Boolean
    Dim x As Integer
    For x = 0 To F1.Lb.ListCount
        If LCase(pathName) = LCase(F1.Lb.List(x)) Then
            'It Exists
            F1.Lb.List(x) = pathName
            AddListBoxItem = False
            Exit For
        Else
            AddListBoxItem = True
    Next x
    If AddListBoxItem = True Then
       F1.Lb.AddItem pathName
    Else
       MsgBox "Item already exists"
End Function
i thought (via a google searches) that using "contains" as below was supposed to compare, but contains was not avail.
  F1.Lb.Items.Contains(pathName)
thoughts?
