THTom Hickerson12/03/2019
I have a macro that adds custom properties to every part in an assembly, and one that updates the material type if its not already set. I was trying to make them run together so, but can't figure out how to pull it off. I tried different variations but keep running into trouble with the swmodel and swpart
Option Explicit
Dim swModel As ModelDoc2
Dim vComps As Variant
Dim i As Integer
'Dim Proj_num As String
Set swModel = swApp.ActiveDoc
Debug.Print "Starting with "
'Proj_num = InputBox("Enter Project Number")
'updateProperty swModel, proj_num
If swModel.GetType = swDocASSEMBLY Then
Set swAssy = swModel
vComps = swAssy.GetComponents(False)
For i = 0 To UBound(vComps)
Set swComp = vComps(i)
If swComp.GetSuppression = swComponentFullyResolved Then
Set swModel = swComp.GetModelDoc2
changeMet swComp.Name
Else
MsgBox swComp.Name & " is lightweight or supressed. Macro stopping"
End
Next i
Function updateProperty(swModel As SldWorks.ModelDoc2) As Boolean
Dim cpm As CustomPropertyManager
Set cpm = swModel.Extension.CustomPropertyManager("")
cpm.Add2 "Project", swCustomInfoText, ""
cpm.Add2 "Description", swCustomInfoText, ""
Debug.Print "File " & i & " updated"
End Function
Here is the second one
Option Explicit
Set swPart = swModel
Debug.Print "File = " & swModel.GetPathName
Debug.Print " Old part material = " & swPart.MaterialIdName
If swPart.MaterialIdName = "Steel" Or swPart.MaterialIdName = "" Then ' This item does not have a material set"
' Apply new material. This operation overwrites the information in
' ModelDoc2::MaterialIdName and PartDoc::MaterialIdName.
swPart.SetMaterialPropertyName "SolidWorks Materials.sldmat", "ASTM A36 Steel"
