Hi Guys,
I've googled this 500 different ways and cannot find the answer - how do I get rid of the green origin symbol when I export to an eDrawings format. SW18' SP3 if it matters.
Thanks!
Hi Guys,
Thanks!
Hmm, you are indeed correct. I already had "Hide All Types" selected, but that did not suppress the COM symbol. To get it to properly suppress, I had to disable Hide All Types (basically 'view all'), then uncheck all the view options one by one. Only then did the eDrw export correctly.
I would have expected Hide All Types to do this, but it did not (for anyone else with a similar problem)
Anyways, thank you very much for the help David
Go to the drawing select view, then Hide show, then Center of mass. Select it to turn it off.
