Please I need help support regarding a sheet metal part one's that is suppose to create using Bend Lofted Bends,
the thickens is 0.25" material 44W, and Bend Radius 0.0625" K 0.50, number of faces close to 20-24, unfortunately everything what
I try didn't work,PLEASE see the file in attach with the geometry, units are in imperial, inches and the dimensions are critical only the Bend Radius may be could be variable with some limits, THANK YOU SO MUCH for a fast urgent solution or solutions if there is possible.
Best,
Sorin,
like that? 21 faces.
