Hi to everyone
Have you any idea how can i do this pattern? scr25
Thank you for your time
Kostas
PS the instances of the pattern are parametric from custom property
Second PS
I have attached an new screenshot with what i'd like to do
Regards
Hi to everyone
Kostas
Second PS
Regards
As mentioned above, sketch driven pattern of the hole, but also u could to table driven pattern (where u put coordinates for next instance) or variable pattern.
Hi Wojciech
Thank you for your answer but
as i mentioned before the number of the holes managed from a custom property variable (e.g 1 hole or 2 holes or 3 holes or...)
and i think the table driven pattern is not suitable
Regards
Kostas
Kostas Stergiopoulos wrote:
Hi Wojciech
Regards
Kostas
You can use a custom property to drive the number of instances in a Pattern. See How do I set a configuration specific dimension or value?
Create a sketch, in which your custom property determines the location of those holes or points. Then create your feature from this sketch. Or do the sketch as mentioned, then make your feature, then use a sketch driven pattern to complete it out.
