Hi all, I'm having a little bit of frustration with a drawing I made recently.
I created a part then converted it to sheetmetal as you can see in the attached files.
However some of the dimensions will not import and/or do not update on the drawing.
Specifically my issues are as follows:
- Patterned hole callout (1/4" Clearance) model item will not import into drawing.
- Patterned & mirrored screw thread (1/4-20) model item not importing.
- Sheetmetal thickness won't import into drawing.
- I have altered the (sheetmetal) thickness and that is not reflected in the drawing. Had to override the value to get this drawing out.
Basically every dimension that is shown as a reference (grey) wouldn't import although they are defined in the part.
What is going on here? I imagine this is quite a simple fix but I can't seem to figure it out.
Hi Paul Millhouse ,
They grey dims are driven and have override checked. They should be driving dimensions without override checked.
Replace the grey dims for new driving dimensions.
