Hi everyone,
I'm doing holes in a plate. I cavitated one hole, did a sketch driven pattern with 2 points and mirrored it with right plane to get total of 4 holes in the upper half of the plate. When I try to mirror it again for the bottom half of the plate, the mirror preview looks ok, but when I click OK, 2 of the 4 mirrored holes change position in the bottom half. It's not a big deal, I can do it without the mirror, but I'd like to know if someone could explain what's happening?
Preview of the second mirror:
And this is how it ends up:
Part in attachment.
Best regards,
Kari
Kari Lindberg
If you're doing a exact mirror then I would cut the body in half and use the mirror "Bodies" feature - unless you are using the Hole Wizard Feature. If you are using the Hole Wizard you can add a Construction Center Line in the Hole Wizard Placement Sketch...
