Is there a way for me to set a line color to the object lines by default. I see where I can set the line weights but not color in my template.
Example
Object lines to be Yellow
Hidden Lines to be Green
Phantom Lines to be gray
ect.
Example
ect.
I assume you're talking about in a Solidworks Drawing, and not a model? You can set visible model edge and hidden edge colors in Drawings at Tools > Options > System Options > Colors.
I don't know what you mean by "Phantom Lines". And keep in mind that this is a System setting, so if you send a Drawing to another SW user then the file will use the colors indicated by his settings, not yours.
As far as I know your only other option would be to change individual model edges with the icons on the Line Format toolbar.
