When error messages popup the note box is to small to show all of the text. I can't find a setting to correct this issue. The picture shows an error related to the material density but the box isn't large enough to show all of the error message.
Do you have a question? Do you want to know the rest of the message? Do you want this not to happen?
It says what you need to know already. You have overridden the mass. Changes to the model will not change its mass. Changes to the material will not change its mass. Its mass is overridden. Its mass will remain the same. Either don't assign material, or don't override mass, or do that in a different order, or accept this error.
In Windows 10, If you right click on the Solidworks exe and select properties -> Compatibility -> Change high DPI settings -> Override high DPI scaling behaviour by system. (or system enhanced, not sure what the difference is). The messages will fit in the boxes so you can read them, but it also makes the 3D display low resolution.
What happens if you right click and select What's Wrong?
