Having trouble using if statements with axis
Question asked by Matt Sullivan on Mar 7, 2019
Latest reply on Mar 8, 2019 by Matt Sullivan
I am trying to create a simple macro but my VBA is very limited and I can't figure out exactly how to fix this code.
I want to be able to run the macro and if the temp axis is "on", turn it off.
and if the temp. axis is "off" then turn it on.
Any ideas? Am I not setting up a variable or something??
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Set Part = swApp.ActiveDoc
If swUserPreferenceToggle_e.swDisplayAxes = True Then
     boolstatus = Part.SetUserPreferenceToggle(swUserPreferenceToggle_e.swDisplayAxes, False)
     boolstatus = Part.SetUserPreferenceToggle(swUserPreferenceToggle_e.swDisplayTemporaryAxes, False)
If swUserPreferenceToggle_e.swDisplayAxes = False Then
     boolstatus = Part.SetUserPreferenceToggle(swUserPreferenceToggle_e.swDisplayAxes, True)
     boolstatus = Part.SetUserPreferenceToggle(swUserPreferenceToggle_e.swDisplayTemporaryAxes, True)
