I designed an U-shaped bracket using sheet metal and I did the relevant drawing with dimensions and flat pattern. Everything was fine.
After that, due to assembly problems, I needed to split the bracket in two halves, obtaining two bodies. I decided to keep same model, drawing and part number (bad decision, eventually!).
The model has now 2 bodies therefore 2 flat patterns.
After several adjustments to dimensions and show/hide bodies in views, I managed to put the drawing right. What I miss is the bend lines on 'Flat-Pattern3' in the drawing, although the 'Display sheet metal bend notes' flag is checked.
Whilst I can see the bendline on 'Flat-Pattern1' in the model, as it should be, I found there is no bend lines in the 3D model on 'Flat-Pattern3', even if the 'Bend-Lines3' sketch is shown.
This is 'Flat-Pattern1'
and this is 'Flat-Pattern3'
Where are the bend lines?
I'm using SW2017-SP5.
Can someone please check if you have same results?
Part and drawing attached.
