RERob Edwards05/03/2019
I think this is a very similar problem to my previous question -
Editing in the Assembly context seems to make selecting pretty confusing, with some methods working just fine and others not so.
The problem I am having is when I try and keep track of Sketch Segments as I create them to later add relations it just doesn't work.
In the following code it works just fine if I use
2018 SOLIDWORKS API Help - GetSketchSegments Method (ISketch) or 2018 SOLIDWORKS API Help - GetSketchPoints2 Method (ISketch)
but with the Objects returned from Creation Methods
eg
2018 SOLIDWORKS API Help - CreateLine Method (ISketchManager) or 2018 SOLIDWORKS API Help - CreatePoint Method (ISketchManager)
nothing happens. I imagine my code would get too complicated if I have to get all the segments everytime
To illustrate here's a sample of my code that works. The commented out lines don't work.
If Not Haunch1 Is Nothing Then
id = 1
With .SketchManager
.Insert3DSketch True
.AddToDB = True
Set swSketch = .ActiveSketch
With swSketch
.Name = pm.Description("_") & "_Secret_Haunch" & id
.Description = pm.Description & " Secret Haunch" & id
Set swSkRelMgr = .RelationManager
End With
Dim Triangle(1 To 3) As SldWorks.SketchSegment
Set Triangle(1) = .CreateLine(0#, 0#, 0#, 0.1, 0#, 0#)
Set Triangle(2) = .CreateLine(0.1, 0#, 0#, 0.1, 0.1, 0#)
Set Triangle(3) = .CreateLine(0.1, 0.1, 0#, 0#, 0#, 0#)
ReDim EntsArr(1)
Set EntsArr(0) = pm.CheekPlane(1)
'This works!
'Dim vSketchEntities As Variant 'already defined earlier in sub
vSketchEntities = swSketch.GetSketchSegments ‘ <- WORKS!
For i = 1 To 3
'Set EntsArr(1) = Triangle(i) ‘ <-DOESN’T WORK
Set EntsArr(1) = vSketchEntities(i - 1) ‘ <- WORKS!
Call swSkRelMgr.AddRelation(EntsArr, swConstraintType_COINCIDENT)
Next
ReDim EntsArr(2)
Dim swSkPt As SldWorks.SketchPoint
vSketchEntities = swSketch.GetSketchPoints2 ‘ <- WORKS!
For i = 1 To 3
'Set swSkPt = Triangle(i).GetStartPoint2 ‘ <- DOESN’T WORK
'Set EntsArr(2) = swSkPt ' <- DOESN'T WORK
Set EntsArr(2) = vSketchEntities(i - 1) ‘ <- WORKS
Select Case i
Case 1
Set EntsArr(0) = pm.HaunchPlane
Set EntsArr(1) = pm.EndPlane(id)
Case 2
Set EntsArr(0) = pm.StartPlane
Case 3
Set EntsArr(1) = pm.EdgePlane(id)
End Select
Call swSkRelMgr.AddRelation(EntsArr, swConstraintType_ATINTERSECT)
Next
.AddToDB = False
End With
I asked my VAR and the creative solution he proposed was to ignore the returned object but immediately use 2018 SOLIDWORKS API Help - GetSelectedObject6 Method (ISelectionMgr) to capture it.
I've not tested it yet. I wanted to reach out and ask is there a better way/ something I'm doing wrong to keep running into these problems.. or is that just the way it is?
