This one's absolutely doing my head in.. I swear it worked yesterday, but I could be wrong.
I'm editing a new sketch in context of an Assembly. I added a few dimensions that are driven.
If the value of a certain dimension is below a threshold I want to delete it.
I kept the DisplayDimension object returned from creating it and am following the advice in this post...
namely to get the annotation to select prior to deleting.
From what I can tell, I have the correct dimension. The call to select returns True but it doesn't get deleted.
I also get this box pop up with the messsge
"Entities that do not belong to the active sketch cannot be deleted."
When I add a break point after selection and manually select the dimension, it works just fine.
Somethings not right.. and I don't have a clue what else to try.
Here's the code
'Add dimensions
Dim Haunch_swDD As SldWorks.DisplayDimension
Set Haunch_swDD = AddDimensionBetweenSketchPointAndEntity(vSketchEntities(0), pm.Haunch, "ThisOne")
Haunch_swDD.GetDimension.DrivenState = swDimensionDriven
Select Case True
Case Haunch_swDD Is Nothing
Case IsVerySmall(Haunch_swDD.GetDimension)
Dim swAnn As SldWorks.Annotation
Debug.Print Haunch_swDD.GetNameForSelection
Set swAnn = Haunch_swDD.GetAnnotation()
If swAnn.Select3(False, Nothing) Then
Debug.Print "name:" & swAnn.GetName & vbCr & "Type:" & swAnn.GetType
Debug.Print swModel.Extension.DeleteSelection2(0)
Private Function AddDimensionBetweenSketchPointAndEntity(ByVal p As SldWorks.SketchPoint, e As SldWorks.Entity, Optional DimName = "") As SldWorks.DisplayDimension
p.Select4 False, Nothing
e.Select4 True, Nothing
Dim swDD As SldWorks.DisplayDimension
Set swDD = swModel.AddDimension2(p.X, p.Y, p.Z)
If Not swDD Is Nothing And DimName <> "" Then
swDD.GetDimension.name = DimName
Set AddDimensionBetweenSketchPointAndEntity = swDD
End Function
