Kindly need help on how to convert from a surface body to a solid body for my project. I have tried to knit the surfaces together but does not work because of the big tolerance.
Here is the link for the file
https://drive.google.com/open?id=1uGM48jJgVZ6AMJUnzwF6TTS0m4CoPVTL
Hello Saran,... it's possible,.. I saveas a sldprt, find the center and saveas parasolid (front/rear/bottom).. and assembly using vertex matches for the mates.. and saveas parsolid,.. knit the front/rear.. then knit the bottom.. and repair/close failures and solidify.. (image)
..these are big files though.. but could zip each out as independent?
