PDM add variable while add file to vault
Question asked by Pichaiyan Prabaharan on Mar 1, 2019
Latest reply on Mar 3, 2019 by Amen Allah Jlili
I try to add a variable to the file when I add file to vault using below codes.
  Select Case poCmd.meCmdType
            Case EdmCmdType.EdmCmd_PostAdd
                MsgBox("File added")
                Dim AffectedFile As EdmCmdData
                For Each AffectedFile In ppoData
                    Dim FileName As String
                    Dim fileType As String
                    FileName = AffectedFile.mbsStrData1
                    MsgBox(FileName)
                    Dim myVault As IEdmVault5 = CType(poCmd.mpoVault, IEdmVault5)
                    Dim myfile As IEdmFile5 = myVault.GetFileFromPath(FileName)
                    Dim myvars As IEdmEnumeratorVariable5
                    myvars = CType(myfile.GetEnumeratorVariable(), IEdmEnumeratorVariable5)
                    fileType = FileName.Substring(FileName.Length - 6)
                    fileType = fileType.ToUpper()
                    Dim Rev_0 As Integer
                    Dim Get_Rev_Latest As Integer
                    Rev_0 = 0
                    If fileType = "SLDPRT" Then
                        MsgBox("Setting rev")
                        myvars.SetVar("Rev_Latest", "@", Rev_0)
                        myvars.closefile(True)
                Next AffectedFile
its not showing the added value until check in and check out file.
I want to see the values in card immediately once i added file to the vault.
may I know what I'm doing wrong?
