Miter flange: spacing between bends is not right, how can I check it?
Question asked by Pierre-Antoine Mangeret on Feb 28, 2019
I looking around the Sheet Metal module and I have been playing with Miter Flanges a little bit.
I ended up doing such a structure where I see an issue but I do not know how to check it.
As you can see, the 5th bend from the left is square, and not rounded.
The explanation is clear: there is not enough distance on that edge to fit two bends. I can fix it if I see it.
Now my question is: how can I check that if I didn't see it visually?
I checked with 'check' from the evaluate tab but it didn't point that error.
Note that it builds properly as well.
Also, I believe this is not correct for manufacturing as the thickness in that corner is thicker than the metal sheet. Is that correct?
Thanks!
