Next without For macro problem
Question asked by Sean Leahy on Feb 28, 2019
Latest reply on Feb 28, 2019 by Christian Chu
i am trying to get this code to work and can't figure out why i get the error Next without For. any help would be helpful.
Dim Part As ModelDoc2
Dim boolstatus As Boolean
Dim colDrawing As Collection
Dim EXL As Excel.Application
Dim drawExlSheet As Excel.Worksheet
Dim tempWbook As Workbook
Set colDrawing = New Collection
Set EXL = GetObject(, "Excel.Application")
Set tempWbook = EXL.ActiveWorkbook
'MsgBox tempWbook.Name
Set drawExlSheet = tempWbook.ActiveSheet
Dim fileLocation As String
Dim fileName As String
Dim fileType As String
Dim fileConfig As String
Dim savePath As String
'savePath = "U:\Desktop\test folder for macros"
Dim i As Integer
'rows 2 to 100
For i = 2 To 5
    fileLocation = drawExlSheet.Range("B" & i).Value
    fileName = drawExlSheet.Range("C" & i).Value
    fileConfig = drawExlSheet.Range("D" & i).Value
    fileType = drawExlSheet.Range("E" & i).Value
    If fileType = "" Then
        Next i
    If fileName <> "" Then
        Set Part = swApp.NewDocument("Q:\Product Development\Common Parts\SOLIDWORKS TEMPLATES\Drawing.slddrt", 10, 0.594, 0.841)
        'swApp.ActivateDoc2 "Draw1 - Sheet2", False, longstatus
        Set Part = swApp.ActiveDoc
        longstatus = Part.SaveAs(fileLocation & fileName & ".SLDDRW")
        colDrawing.Add Part, fileName & ".SLDDRW" '???
'        MsgBox fileName & ".SLDDRW"
Next i
'activate the required drawing file and add code to update the drawing file
Dim tempModelDoc As ModelDoc2
Set tempModelDoc = colDrawing("ABC-26.SLDDRW")
swApp.ActivateDoc tempModelDoc.GetTitle()
swApp.CloseDoc tempModelDoc.GetTitle()
