Does anyone know if there is a way to utilize "marked for drawing" dimensions for your drawing while using virtual components? I can get the virtual component to show up in the drawing but I can't get the "marked for drawing" dimensions to show in the drawing. Other marked for drawing dimensions located at the .sldasm level are coming through fine so my use of the feature appears to be correct. I suspect possibly you can't use marked for drawing dimensions in conjunction with virtual components but I can't find anywhere that it specifically says that...
Jason
