Complie Error: Type mismatch: array or user-defined type expected when using EdmPoint
Question asked by Jesse Meiring on Feb 26, 2019
Latest reply on Feb 26, 2019 by Artem Taturevych
My current issue is a "Complie Error: Type mismatch: array or user-defined type expected" when I try to use the GetArrowVerticies on a transition I find in the vault. I can't seem to determine how to define the EdmPoint properly. Any help is greatly appreciated! Thanks!
Code:
Dim swApp As Object
Dim vault               As IEdmVault8
Dim WorkflowMgr         As IEdmWorkflowMgr6
Dim Workflow            As IEdmWorkflow6
Dim WFpos               As IEdmPos5
Dim Trns                As IEdmTransition10
Dim Tpos                As IEdmPos5
Dim State               As IEdmState6
Dim Spos                As IEdmPos5
Dim AVx()               As EdmPoint
Set vault = New EdmVault5
vault.LoginAuto "Vault", 0
Set WorkflowMgr = vault.CreateUtility(EdmUtil_WorkflowMgr)
Set WFpos = WorkflowMgr.GetFirstWorkflowPosition()
Do While WFpos.IsNull <> True
    Set Workflow = WorkflowMgr.GetNextWorkflow(WFpos)
    Debug.Print "~ID = " & Workflow.ID & " Name = " & Workflow.Name
    Debug.Print " -States-"
    Set Spos = Workflow.GetFirstStatePosition()
    Do While Spos.IsNull <> True
        Set State = Workflow.GetNextState(Spos)
        Debug.Print "   ID = " & State.ID & " Name = " & State.Name
    Loop
    Debug.Print " -Transitions-"
    Set Tpos = Workflow.GetFirstTransitionPosition()
    Do While Tpos.IsNull <> True
        Set Trns = Workflow.GetNextTransition(Tpos)
        Trns.GetArrowVertices (AVx())  '<--- This is the line that is highlighted when I compile
        Debug.Print "   ID = " & Trns.ID & " Name = " & Trns.Name
    Loop
Loop
