I'm trying to reorganize my company's title block, and the "Snap to rectanlge center" doesn't seem to work very well, so I decided I would manually place the notes within the lines. The problem is, the locations for the notes ("Parameters" section in the note properties) are twice what it should be. I moved the bottom left corner of the title block to the origin so i can easily do the math to find the centers of each rectangle, but every note location is double what it should.
For example, lets say that the box that starts at zero, and is 100mm long and 50mm tall, which means it center is (50,25). The note that is center justified vertically and horizontally, needs to be at (100,50) to be at the center of that box.
Is there some scaling setting I'm unaware of? I can get through this dealing with this issue, but its a pain.
That has been an issue for a while:
Can someone please explain x/y coordinates in note parameters in drawings? (SW 2014)
Try this instead:
Dimensioning to Text in Drawing
