IF THEN STATEMENT ON PART PROPERTY TO DRIVE A SPECIFIC DRAWING
Question asked by S. Harvey on Feb 21, 2019
Latest reply on Feb 23, 2019 by Deepak Gupta
I would like a macro to choose which drawing to reference and build a new drawing from based on a Custom Property.
I can see the finite number of drawings required to:
     -make every possible drawing without dangling dimensions
     -create more or less views
     -create special annotations
     -change the scale so views fit
My workflow is:
     1) Input Parameters into DriveWorks Xpress
     2) Produce the Model from DriveWorks Xpress (Generates the Custom Property "Drawing Code" from rules in DriveWorks)
     3) User Runs the Macro with the New Part open
               a) Code looks at the Custom Property "Drawing Code"
               b) Through If then Statements finds the correct Drawing associated with the code "Drawing Code"
               c) Copies that Drawing, changes references and saves to the current folder of the New Part
I don't have Solo or Pro and I understand there is more functionality but for now I'm locked into Xpress.
_______________________________________________________________
This is the Property lookup and currently works for step 3a.  I borrowed and tweaked this.  There is a condition to create a new custom property which I named Drawing #.  I would override this with the code to create the new drawing.
Option Explicit
Dim swCustProp As CustomPropertyManager
Dim ValOut As String
Dim ResolvedValOut As String
Dim wasResolved As Boolean
Set swModel = swApp.ActiveDoc
Set swCustProp = swModel.Extension.CustomPropertyManager("")
swCustProp.Get5 "DRAWING CODE", False, ValOut, ResolvedValOut, wasResolved
If ResolvedValOut = "T11R1" Then
    swCustProp.Add3 "DRAWING #", swCustomInfoText, "GET T11R1 DRAWING", 1
If ResolvedValOut = "T11R0" Then
    swCustProp.Add3 "DRAWING #", swCustomInfoText, "GET T11R0 DRAWING", 1
I am currently hitting a snag with the SolidWorks help file " Replace Referenced Document Example".
I copied and pasted the code exactly.  I replace the file locations accordingly and make sure the assembly is not open as noted in preconditions.
It's producing an error at "Debug.Assert bRet" by highlighting it, no msg box
I know it's probably something dumb but I am trying.  I started with the exact code first then I'll switch it to a drawing instead of an assembly later
I'll then have to figure out the coding to make a copy and move but its a working progress
Thank You for any help.
Option Explicit
Const sReferencingDoc       As String = "C:\Users\Desktop\TESTASSEBMLY.sldasm"
Const sOldDoc               As String = "C:\Users\Desktop\TEST.sldprt"
Const sNewDoc               As String = "C:\Users\Desktop\TESTWITHHOLE.sldprt"
    Dim bRet                As Boolean
      bRet = swApp.ReplaceReferencedDocument(sReferencingDoc, sOldDoc, sNewDoc)
    Debug.Assert bRet
