Please I need help support asap very urgent it is possible I really appreciate, so I created a weldment part and it didn't come with Description parametric direct in cut list,I proceed to create manually the Description and in the same time the Length parameter for every member has error on cut list please there is a solution to resolve this fast and stable in parametric way, THANK YOU so much I appreciate. I use SW sp2.0 2016. Please see the atach file a dwg pdf and the wdtm part too.
Best,
Sorin,
