AAAlex Alex21/02/2019
Hello friends.
I have an assembly model in Solidworks.
I use API C# to Solidworks for automatic create a model.
In a part, I need to set Depth 10 or 40 mm.
Not a single example on the forum helped me.
static SldWorks swApp;
static AssemblyDoc assemblyDoc;
static ModelDoc2 assemblyModel;
static ModelDocExtension swModelDocExt;
static FeatureManager swFeatureManager;
static EquationMgr assemblyMgr;
static IDimension partDimension;
static Feature swFeature;
static IModelDoc2 partModel;
static ExtrudeFeatureData2 swExtrudeFeatData;
public static void getComponents()
Console.WriteLine("getComponents");
Process[] processes = Process.GetProcessesByName("SLDWORKS");
foreach (Process process in processes)
Console.WriteLine("kill process ");
process.CloseMainWindow();
process.Kill();
object processSW = System.Activator.CreateInstance(System.Type.GetTypeFromProgID("SldWorks.Application"));
swApp = (SldWorks)processSW;
swApp.Visible = true;
//open file
int fileError = 0, fileWarning = 0;
string pathToFileAssembly = "C:\\Users\\administrator\\Desktop\\SW\\AssemBelt.SLDASM";
assemblyModel = swApp.OpenDoc6(pathToFileAssembly, (int)swDocumentTypes_e.swDocASSEMBLY, (int)swOpenDocOptions_e.swOpenDocOptions_Silent, "1", ref fileError, ref fileWarning);
assemblyDoc = (AssemblyDoc)assemblyModel;
assemblyMgr = assemblyModel.GetEquationMgr();
swModelDocExt = (ModelDocExtension)assemblyModel.Extension;
swFeatureManager = (FeatureManager)assemblyModel.FeatureManager;
object[] comps = assemblyDoc.GetComponents(true);
Console.WriteLine("Solidworks comps size = " + comps.Length);
foreach (Component2 icomp in comps)
partModel = swApp.OpenDoc6(icomp.GetPathName(), (int)swDocumentTypes_e.swDocPART, (int)swOpenDocOptions_e.swOpenDocOptions_Silent, "1", ref fileError, ref fileWarning);
switch (icomp.Name)
case "Part-1":
break;
case "Part-2":
break;
case "Part-3":
if (true)
partDimension = (Dimension)partModel.Parameter("hiegth@Sketch4");
partDimension.Value = 120;
partDimension = (Dimension)partModel.Parameter("thickness@Sketch4");
partDimension.Value = 5;
//THIS DOES NOT WORK
PartDoc doc = (PartDoc)partModel;
swFeature = doc.FeatureByName("Base-Extrude");
swExtrudeFeatData = swFeature.GetDefinition();
swExtrudeFeatData.SetDepth(true, 0.04); //or 10 mm or 40 mm
swFeature.ModifyDefinition(swExtrudeFeatData, partModel, null);
icomp.SetSuppression(1);
icomp.ReferencedConfiguration = "type-B";
else icomp.SetSuppression(0);
break;
Console.WriteLine(icomp.Name + " => " + icomp.GetPathName() + " => " + partModel);
}//for end
On this line, the program breaks down:
swFeature equals NULL.
Thanks!
