Macro to do a section view down to an Axis
Question asked by Matt Sullivan on Feb 21, 2019
Latest reply on Feb 26, 2019 by Fifi Riri
Hi Guys. Love the forum you're a lot of help. I started doing a few macros and I'm stuck on one that will help me save some time.
I created a macro that takes a part drawing, and opens up a 2D drawing template with predetermined views.
This all works great. I used this forum and the record macro feature combined.
Now I am stuck on this part.
I need a partial cross section of a specific view. I get there by displaying axis, draw box, select "broken out section" feature and click the axis.
The section view cuts down to the axis of a revolved part nicely.
I can't get the record feature to work because when the section happens, it isn't referencing the axis as a "stop cut" point, it is using the distance value of the specific part I'm recording.
I believe this part to be my issue in the code below.  "Part.CreateBreakOutSection 3.61338130073942E-03"
Hopefully that makes sense, I'm sure it does you're smart people.
Your help would be fantastic.
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Set Part = swApp.ActiveDoc
boolstatus = Part.SetUserPreferenceToggle(swUserPreferenceToggle_e.swDisplayAxes, True)
boolstatus = Part.SetUserPreferenceToggle(swUserPreferenceToggle_e.swDisplayTemporaryAxes, True)
boolstatus = Part.ActivateView("Drawing View8")
boolstatus = Part.Extension.SetUserPreferenceToggle(swUserPreferenceToggle_e.swSketchAddConstToRectEntity, swUserPreferenceOption_e.swDetailingNoOptionSpecified, False)
boolstatus = Part.Extension.SetUserPreferenceToggle(swUserPreferenceToggle_e.swSketchAddConstLineDiagonalType, swUserPreferenceOption_e.swDetailingNoOptionSpecified, True)
Dim vSkLines As Variant
vSkLines = Part.SketchManager.CreateCornerRectangle(0.021695343274111, 0, 0, -2.54349947452516E-02, 1.06324886917547E-02, 0)
boolstatus = Part.Extension.SelectByRay(0.142251506759536, 4.66699951634164E-02, 0, 0, 0, -1, 6.40012578196038E-04, 5, True, 0, 0)
Part.ClearSelection2 True
boolstatus = Part.SetUserPreferenceToggle(swUserPreferenceToggle_e.swDisplayAxes, False)
boolstatus = Part.SetUserPreferenceToggle(swUserPreferenceToggle_e.swDisplayTemporaryAxes, False)
