MHMartijn Hoogerwerf20/02/2019
Hi there.
At our company we have standard positions for the BOM on a drawing. The most used position is saved in the drawing template. To move the BOM to another location we manually edit the Bill of Materials Anchor point (Go to Sheet Format - RMB - Set anchor - select the desired position). I want to automate this: make it a single click method to switch between positions. My thoughts are to do this by editting the BOM anchor coordinates (the position is not one of the standards like: swBOMConfigurationAnchor_BottomLeft). But I can't find if that is possible and if so how to make use of it.
I allready looked here (and more):
2018 SOLIDWORKS API Help - ITableAnchor Interface
2018 SOLIDWORKS API Help - Get and Set Table Anchor of Hole Table Example (VBA)
2018 SOLIDWORKS API Help - swBOMConfigurationAnchorType_e Enumeration
2017 SOLIDWORKS API Help - Get Table Anchor Example (VBA)
2018 SOLIDWORKS API Help - Insert BOM Table Example (VBA)
I appreciate any help with this. Maybe i should use another approach.
(this is my first question here btw)
