DGDamir Galic20/02/2019
Hi, is there a way to add external load to surface of an object in limited area with just a mouse click on the surface where you want the force without using split line to limit the area? (area can be approximate since it's rough simulation)
For example I got some stuff on the beams on which force is acting...
And then to speed things up I remove those and I am left with blank surfaces.
