Hi everyone,
I have a problem with drawings when I use DriveWorks. I have drawing with three sheets. First sheet is for assembly and others are for parts of that assembly. Now It changes the assembly sheet only when I generate new model in Driveworks. How to make it change also part sheets?
Ruff example drawing with 3 sheets. Other two sheets are parts with dimensions. Part sheets are now linked on original parts and they don't change when generating new model with DriveWorks.
Many Thanks
Ville Kahelin
Can you share the complete files to check and I had created projects like this in past without this kind of issue.
