Ref doc - GetBendState
Question asked by Niels Raahauge on Feb 18, 2019
Latest reply on Feb 20, 2019 by Niels Raahauge
I am building a macro to find open document type and model type - (sheetmetal, multipart, weldmentpart)
How can I use the same command? and why is the command vDepend(1).GetBendState not working?
If swModel is drawing - then test on referenced document -point to swModel and use the same commend as if it  swModel is a part  (swModel.GetBendState <> 0 )
'Is the document a sheet metal part part?
Option Explicit
Public swApp As SldWorks.SldWorks
Public swModel As SldWorks.ModelDoc2
Public Sheet As Object
Public SheetName As String
Public View As Object
Public Ref As Object
Dim vDepend     As Variant
Dim RefExtension()  As String 'Find extension
Set swModel = swApp.ActiveDoc
If swModel.GetType = 1 Then 'If swModel is a SWP do
    If swModel.GetBendState <> 0 Then Debug.Print "shet metal part"    'SheetMetal SWP-SM
If swModel.GetType = 3 Then 'If swModel is a SWD do
    Set Sheet = swModel.GetCurrentSheet()
    Set View = swModel.GetFirstView
    Set View = View.GetNextView
    If View Is Nothing Then swApp.SendMsgToUser ("No views found on drawing")
    Debug.Print "swModelName = " & swModel.GetPathName 'Name of active doc drawing
    Set Ref = View.ReferencedDocument 'find ref model to drawing
    vDepend = swApp.GetDocumentDependencies2(swModel.GetPathName, True, True, False)   'Document, Traverseflag, Searchflag, AddReadOnlyInfo
    Debug.Print "Model in drawing view =" & vDepend(1)
    Stop 'Why does next  command not work?
    If vDepend(1).GetBendState <> 0 Then Debug.Print "shet metal part"
    'How can I point vDepend(1) to swModel, and use the same symtax as I used for the part?
    'Set swModel = vDepend(1)
    'If swModel.GetBendState <> 0 Then Debug.Print "shet metal part"    'SheetMetal SWP-SM
