Hi
Is there any way to close or minimize the gap in the image or what are your suggestions?
Best regards,
Hi
Best regards,
HUSEYIN BAYRAM - Maybe Frank Ruepp can explain how SolidWorks calculates the Bend Area and mention if there is another thing that could be done to help you..
Hi All,
there are a couple of things about these corners:
Perhaps this helps to understand why we have to use these big corner reliefs, how you can get around them and why you are perhaps mssing the Corner Relief feature even though you are using i.e. 2018.
Kind regards
Frank
SOLIDWORKS Product Defintion Team
Very nice description.. Thank you Frank Ruepp .
Can you add this piece you draw? Please.
Thanks again!
English is not my first language - If you point out my mistakes I'd be very grateful..
Hi All,
In this case we can create a full round corner (top picture) or a suitcase corner with relief:
And we can create the flat pattern of it:
Notice that you have to turn off "Show Slit" in order to get the optimized (geometry added to the flat) flat pattern:
With 2013 we have changed the multi body sheet metal architecture and we have a global sheet metal defintion and body specific sheet metal defintions always at the top of the Feature Tree:
Since then we have developed quite some sheet metal features (i.e. Corner Reliefs) and mostly all of the new sheet metal features do not support the old architecture. Therefore we do not show the new features when we detect a part with the old sheet metal architecture. So therefore you migh be missing the Corner Relief feature:
Kind regards
Frank
