How do you draft this simple block?
Question asked by Jody Holm on Feb 15, 2019
Latest reply on Feb 15, 2019 by Tony Tieuli
I got a block with a slopped top. I want 10 degrees draft from the top to the bottom. I need to hold the dimensions at the top (see attached) and draft 10 degrees down from the 4 top edges. In Pro/e you would just select the top plane as your neutral plane, select the wall you want to draft, and select the edge (or surface) you want to draft from and the sides would flare out to the plane. I this possible in Solidworks? I have attached a picture of what it should look like.
