Hey. Tell me how to export the entire assembly of sheet metal in DXF? Or export the part from the sheet metal but first determine the maximum area for if the part was built was not true. Thank.
Dmytro, could not understand your above statement. Can you please elaborate?
Ok. If i build some detail wrong (projection was do not match) i need measure which of surfaces has maximal square.
In file what i was connect almost all try but:
1. Filename hasn't configuration. Example (det-00.dxf)
2. Filename has *.SLDPRT.dxf extantion. I need *.dxf
3. I want choose path to export files.
Thanks for the mention, Nilesh Patel.
Dmytro Kalyukh I think you can only export individual parts as a flat pattern, not an entire assembly. You need to use API calls like IPartDoc.ExportFlatPatternView or IPartDoc.ExportToDWG2 (yes, it can export as a DXF). Anyway we can certainly help you write a custom program if you need. I have a macro that does this for a selected item in a cut list called "Export flat pattern as DXF" in our Macro Library. It is only available to premium members, however. Perhaps you were not looking to spend money on this but I wanted to at least make you aware of this option. Good luck.
Keith
I was find some macro but i can't fix it as i want. Can some one help me?
https://filebin.net/nyrnad3fcwhx5jol
